unconfigure igmp snooping vlan ports set join-limit
unconfigure igmp snooping {vlan} vlan_name ports port_list set join-limit
Description
Removes the join limit set on VLAN ports.
Syntax Description
vlan_name Specifies a VLAN name.
port_list Specifies one or more ports or slots and ports.
Default
No limit.
Usage Guidelines
None.
The following command removes the join limit for port 2:1 in the Default VLAN:
unconfigure igmp snooping "Default" ports 2:1 set join-limit
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IGMP snooping feature, see the Switch Engine v33.1.1 Licensing Guide document.
